shutterfreak
- Joined
- Dec 22, 2011
- Messages
- 3
- Points
- 1
A couple weeks ago the cabin fan from my 1999 Punto 1.7 TD died. Whatever position I selected from the central console switch (0-1-2-3) didn't bring the fan to live. First I checked the fuses, but they were all okay. Then I called my garage to see if they could have a look.
To make a long story short, it was the heater resistor pack that died. That's basically a set of fixed value resistors that are put in series with the cabin fan to control its speed. Pretty simple and not very energy efficient since the resistors dissipate heat when current flows through them. That heat can be lethal to the resistor, which must have happened with mine.
Okay, I should be able to source a new one in aftermarket channels I thought. Apparently not
- neither in the new nor in the used parts markets I could find a replacement.
It appears that Punto cars like mine had 3 different makes of internal heater fan / resistor pack units. Mine, a Valeo brand, can apparently no longer be sourced, not even in scrapyards (so far no luck).
The part is still listed on the Valeo online catalog (part number 508869, EAN 3276425088696 ) but alas, I can't source it over here. Even on the 'bay I couldn't find one. I added a couple images to show which part I mean (I hope this is okay):
So, for the time being, I "bridged" the heater resistor pack by means of a wire bridge in the connector normally attached to the heater resistor pack, and connected the thick wire going to the motor with the closest wire (blue), which is linked to the 1st speed setting on the fan speed selector in the central console. At least I have heat again, be it at full fan speed for now.
Since I know how to handle a soldering iron I'd consider either repairing the current defective resistor pack, or "upgrading" it with a DC/DC converter.
Sadly, disassembling the resistor pack does not seem to be working, unless I go ahead and try to unsolder the 4 lips of the PCB with the as of yet invisible electronics (I expect to find 3 resistors, maybe one diode).
The DC-DC track would be much more energy efficient, requiring much less heat to dissipate... if I know for sure that the fan motor will like being fed with a switched DC power source (it's basically a PWM circuit which I'd lock in 3 different PWM settings available through the speed selector in the central console).
Any opinions on the track(s) to pursuit?
Best regards,
Olivier
Best regards,
Olivier
