Two years later, I finally got around to this; granted, over a year was in storage, but anyways. In the end, @F123 was correct, the tab was bent under. I took a drill bit and punched it back, but the arm still wouldn't budge. After taking a wrench to pry, it started to budge. Eventually, it gave way and I found out the PO had epoxied the arm to the spindle, rather than replace one or the other. The spindle is knackered a bit, so I'll eventually need to replace it, but that's a project I'm not undertaking until I redo the body
As an interim solution, I drilled a tiny hole and threaded it for a little stainless set screw. That allowed me to clock it properly and cinch it down. A shorter set screw would be invisible, but either way, it'll work for the time being.
And, hi again
... it's been awhile, but I had to retire, move, get a job, build a house, and then move everything (including the Fiats) back in and get back in action, but I can focus on fiddling with the Fiats again.
View attachment 424872View attachment 424873
