well backfiring is usually timing so it may be you need to turn the dizzy around more to change the firing point
That's an unusual boot lock?
Hi Damian---what engine have you got in the back of your 'wee beastie' and what carb? 'Webcon' can supply the jets you require, and I have the basic carb settings for the 500 and 126 engines if you need/want them.![]()
By co-incidence, I was reading the manual for my Fiat 900e Amigo and find the threads for the belt mountings on that are listed as 7/16 x 20 UNF 2B; worth a try if you happen to have that tap available as it sounds possible given your quick observations.
getting it MOT'd
