Hi all.
Myrtle has recently been messing around going into gear. Gears were very notchy and difficult to engage, with reverse almost always grating or failing to select. At 93,500 miles I was obviously fearing the worst and pricing a new clutch.
I just thought I'd browse the forums and see if there was a quick fix, when low and behold I came across a post suggesting that lubrication of the clutch release arm on top of the gearbox has solved similar issues in the past.
I removed the airbox and liberally sprayed the arm with WD 40 and worked the clutch. Almost immediately the gears became easier to select. I continued lubing and working the pedal for about twenty minutes. Reverse is now the easiest gear to get in to! 24 hrs. later and the gears are almost like new, to select. I am shortly going to more permanently lubricate the pivot on the arm with a slightly heavier oil (3 in 1 or similar) and then walk away!
I am sure that there are many people out there like me who believe they have a clutch issue when all they may have is a lubrication problem.
Not my idea, but I'm buggered if I can find the original post, which also had pictures. If I find it, I'll link to it.
Hope this helps. Panda.
