Technical Problems after dead battery recharged
Segdsg
Hi, I have a 2008 Ducato based motorhome. I had a new battery fitted recently but know that something is draining the battery slowly. After finding the battery completely flat recently we recharged it and now have all sort of electrical issues including headlights suddenly switching off(except on full beam), no speedo, rev counter or other gauges, radio not working and remote locking/alarm not working. Is there someone out there suggest what the issue might be and recommend what to check? Thanks.
How did you recharge the battery? On the vehicle or off the vehicle? If on the vehicle, did you use a suitable charger? Have you checked the battery to make sure it is still serviceable, as completely flat batteries can rarely be restored to full performance?
Either way, I suspect you have problems with the Body Control Module (BCM) or BSI as it is referred to by Peugeot. With luck, it will just be a matter of corruption to memory caused either by a faulty battery, loss of power, incorrect charging or incorrect battery removal/replacement.
I mention the Peugeot BSI to save me changing it to BCM in the following procedure, which I have copied and pasted. I suggest following this exactly, to attempt to reset the BCM, and at any time where you may have a need to disconnect or reconnect the vehicle battery in future.
If you have solar panels and a regulator such as the Votronic series, or other facility that has a connection between the leisure and vehicle battery systems, I would recommend covering the panels and disconnecting them from the regulator, plus removing the main leisure battery fuse before disconnecting the leisure battery as well, the restore the connections in the reverse order.
Where the instructions state to wait 3 minutes after closing doors etc, I recommend 10 minutes if the ignition has been on within the previous 10 minutes, to allow the system to go into "sleep" mode.
Note that this procedure on a Docato or similar van with the battery inside the cabin, requires you to be inside the van with all the doors shut etc. as per the instructions before disconnecting or reconnecting the battery, so do the preparatory work such as removing the floor covering and battery tray cover first, then get inside the vehicle, shut all the doors etc. and after waiting the requisite time, disconnect the battery. The negative terminal often has a clip type clamp, rather than a bolt. which makes things easier.
Once the battery has been disconnected, wait at least 5 minutes before reconnecting it.
BSI (Body System Interface) Reboot Procedure
PROCEDURE FOR BATTERY DISCONNECTION
Whenever a vehicle battery has to be disconnected, switch off all equipment, interior lights etc, close the doors leaving the driver’s window open.
Switch off the ignition and remove the key and any diagnostic equipment.
Wait a full 3 minutes before disconnecting the battery.
The BSi must be allowed to go to SLEEP i.e. into "active economy mode". Do not operate any equipment on the vehicle during this time. Remember, even opening the bonnet will wake the BSi on a vehicle fitted with alarm.
If the battery is under the bonnet, open the bonnet first and leave it up.
ALWAYS disconnect any diagnostic equipment and do not operate any other vehicles in the vicinity during the 3 minute waiting period.
PROCEDURE FOR BATTERY RECONNECTION
Unless otherwise instructed by Peugeot or Product Service, you must always carry out the following procedure, often referred to as a "soft re-boot", to minimize the possibility of the BSi corrupting its own software when reconnecting the vehicles battery supply.
Ensure the procedure for battery disconnection has been adhered to and importantly all BSi functions were switched off with the driver’s window left down.
1 Close all doors
2 Remove ignition key if left in ignition
3 Reconnect battery. DO NOT open any doors
4 Wait 10 seconds
5 Switch on headlights through the driver’s window
6 Switch on ignition then start the vehicle and check system functions
Hello segdsg,
See my post 'How Strange' dated 16/08/2020.
I have a 2003, 2.8jtd motorhome and had issues when battery died.
Cartronix fixed the issue(s) and all has been well since.
Hope this helps.
