Ulysse  Problems a plenty
Barbleman
Hi all, just bought myself a ulysse 51 plate 2.0 jtd,
Love the car just a few little things to try and fix,
Starting with the mileage/tripometer it's came on once in the last week for a day and has failed to light up more often that not, also in the cluster the left hand side light is dim over the fuel gauge,which itself is stuck on empty with the fuel low light constantly on,
I have tried to remove the dashboard by removing all the visible screw but the right hand side seems to be stuck maybe a non visible screw I have missed.
Hopefully someone can help me I have tried to find other ulysse dash problems but to no avail.
I have checked all fuses before attempting to remove the dash cluster.
Look forward to a response - Barbleman
I presume you have the 3 dial display as below:
if this is the case proceed as follows:
Prize up and lift away the tray that has the Monchrome display in it and release the connector that's connected to it.
you should now be able to see 2 screws that secure the bottom of it in place. they are located beneath the middle dial. remove these.
It is now just a case of prying the unit forward to remove and unclipping the connector on the rear.
If you require a replacement unit I have one available at a tenner +P&P.
