problem
problem
R
rob_ov_donny
when i drive me car when its cold or not been strted for few hour it chugs off the clutch in 1st gear, any suggestions of what it could be and if it could be a major problem?
tend to need a few more details.. ie when was it last serviced etc..
1997 Fiat Bravo 1.6 SX
RUNNING WELL
Needs some cosmetic work;
-Need to respray front wing (Colour doesnt match);
-Could also do with a clean;
-Need new bump strips;
-Want new wheels.
2 week ago i thought tht was the problem why it was chuggin bit n not firin str8 away so i cahnged plugs filters n put new oil in but it still doin it... when i strt the car the injector warnin light comes on for cpl seconds then goes off
can you try to describe the fault without using the term 'chugs off the clutch', because i dont know what that means :(
There should be a whole host of lights that come on when you turn on the ignition, and apart from the handbrake light, they all go off by themselves once you start the car. So thats perfectly normal, and not indicative of any faults.
What kind of car is it, age, engine size etc?
The more you can tell us, the easier it is to diagnose
Buzz
The champion of the Bravo 1.4
& now ex owner of a Bravo 1.8
bravo 1.6 basicly it chugs in first gear when ur first settin off... i know all warnin lights would come on but the injector one stays on after the others go off
right.. so the car runs rough wen first started, has lack of power, and will not run on all four cylinders...... is that what you mean??
plus it's all very well using txt language but most of us find it hard to understand just what you mean - myself included.
you may use as many letter/words or lines as you want... there is no restrictions here on BOO :)
Tommy K
Tommy K - Have you got the Bottle!!
W
915
wakka
W
T
1
794
Joseph
J
O
3
557
K
V
5
735
Laurie
L
I
2
1K
Dark Lurker
