When i bought the car i noticed that the drive shafts had an end-play of about 2cm both ways from the differential to the flexible couplings. Looked strange but i said it is ok at the time.
Moving the drive shaft at both directions is very easy with no great force needed, kind of free play. Today as i was driving in a hill suddenly transmission lost its grip.
Stopped the car, put first gear and push the car with my hands. It just moved with no problem and i said that's it, Gearbox broke down. Then i noticed that while i was pushing the car fwd the L/H side drive shaft was turning in the opposite direction of the wheel (because of the differential).
Then idea came and i push the L/H drive shaft that was all the way in, into the diff, towards the Flexible coupling and it was reengaged again with the coupling. I drove my car back home with no problems.
According to Haynes manual exploded view of the rear hub parts, there must be a spring between the drive shaft and hub shaft probably preventing the shaft to move freely in and out of the diff or flex coupling. Do you think that my car is missing those two springs? What about yours? can you move the shafts in and out with almost no force?
