lfcurchins
- Joined
- Nov 17, 2005
- Messages
- 20
- Points
- 6
I have a 1996 P Reg Punto which I have had since November, I have already had a problem with the head gasket going on it but forked out £300 for it to be fixed, now lately I have had a problem with gears. Let me explain.
When I put the clutch fully down its seems fine (no noise, no hesitation, perfect) but when I move the gear stick into 1st it will not go, it is very stiff, it will only go if you really force it but it feel as if it will snap, 4/5 times it will not go into first, so I have been starting off in 2nd to get home from work, the problem has only started no more than a day ago.
When going into 2nd, it is slightly stiff and needs a little push but not as much as 1st, then 3rd/4th and 5th are slightly stiffed but fine nevertheless.
Reverse, when I go into reverse it makes a noise (exactly the noise that is made when the car is not in gear properly but you are moving).
What could be the problem? Gear box? Clutch cable? or other???? PLEASE HELP! Thanks!
