Technical  problem with doblo 2007 multijet
chrisincov
Hello to all forum members ,I am new to the forum and was hoping to pick up some advice.my van is a 2007 but has done 130,000 has it is used for courier work.I was having problems with loss of power and no acceleration the van went into the garage and had two new injetors, and the remaining injectors cleaned,it was no better we then fitted a new air meter and a new egr valve.It now runs slightly better but is far from running normal has it still lacks (lots)of power,incidently it runs far better with the air meter disconnected,has anyone had a simular problem?:cry:
have you got turbo boost? if not check wastegate for sticking,also check turbo boost sensor in inlet manifold for contamination
