Technical  Problem with cooling fan speed
jmj
Hi
I have a 2008 Fiat Doblo 1.3 multijet. The cooling fan is running too fast while the motor is on. It happens mostly all the time now. Could it be a problem with cooling temperature sensor or something else?
Please help me.
Thank you.
Assuming you mean the radiator fan, and that its running all the time even if the engine is cold, then then its most likely the sensor.
If its running too fast, are the plastic fan blades connected to the spindle.
Hi
Please help me.
Thank you.
they normally have 2 speeds. ;)
sound like yours is using the higher speed, :eek:
does sound like a fault, :(
MES will test it's function, (y) both Temp reading , and actuation of fan on BOTH speeds,
Charlie
It is not showing anything on dash board.
Where is the temp. sensor placed please?
