Hi together,
I own a Ducato MJ130 2.3L 131 PS from 2012 with DPF. I bought it 1 year ago and had following problems from the day I bought it:
- white blueish smoke during DPF regen (no coolant, unburnt diesel)
At the shop they changed the EGR and changed 2 glow plugs (other 2 could not be removed). This unfortunately did not help, but worsen the situation.
After driving a bit (always longer trips, > 100 km) again white smoke appeared during DPF regen. After another trip without white smoke (= no DPF regen) the engine check lamp & limp mode activated.
I checked DPF differential pressure (very high > 150 mbar) and boost pressure (non existant). After a manual DPF regen (NO white smoke?!) the differential pressure went back to normal values (idle around 5 mbar), but after driving a bit turbo was still not working and Engine check light went on again with error P0236-7A and DPF differential pressure increased a lot during a 40 km trip.
Error codes currently:
P0236-7A Air supply circuit anomaly
P0683-13 Preheating glow plugs signal
One thing I wonder about: Atmospheric pressure is always around 950 mbar, which is in my opinion too low?
First quick check of pressure the low pressure tube going to turbo looks fine.
Going uphill I can only drive around 45 mph, on flat streets around 80 mph
Do you have any ideas why and what has to be done?
Thanks in advance!
Thanks in advance!
- Model
- Ducato MJ130
- Year
- 2012
- Mileage
- 180000
