I have steering issues amongst other things.
At rest or slow speeds, I have had a creaking noise when the steering is moved from side to side for a while. No vibration or other issues, car drives fine, steers well no stiffness etc.
I had presumed top mounts until today when the power steering packed up as I was attempting to pull out of a junction. I thought I had stalled but the engine was still running, got a message about power steering failure so I switched off the engine and re-started, all fine for the rest of the journey but I'm a little concerned.
I'm going to clean all earthing points as some look a little corroded and I occasionally get the temperature warning light and message on start up which I've read can be bad earths but, should I be worried about a larger problem here and if so, could anyone suggest what it may be?
Car is an 06 plate 1.4 8v
Many thanks
Ben
Many thanks
Ben
