I got all the parts needed to convert my Cinq to power steering, does anyone has the wiring diagram for the power steering ECU? I have checked all the other threads with no luck.
Thank you in advance.
Diagram is in the Seicento Technical Manual, in the downloads section, volume 4 somewhere. But, as rallycinq says, you need a speed sensor (or maybe a switch).
Thank you for your help, I will look for the sei diagram.
It is not a problem to generate an impulse like the one from the speed sensor. My big problem is how to make the connections between the ecu and the PAS motor and I hope someone who already made this upgrade has the wiring diagram.
Relooked at mine..the EPS wiring is dead simple, just follow the colours. The only two wires you won't have are the rpm and wheel speed. Without them it works but is at full assist.
Hi, new here, im putting power steering in my sei whach came without power steering. I have the motor and ecu for power steering. Does anyone know which of the smaller wires need to be connected to make the power steering work ? I will want it as sensitive as possible so dont need the speedo connected, any advice welcome, thanks
