Technical  Power steering issue
Andrew jenkins
Haverhill
Firstly Hello from a newbie. My other half's 2012 500 has recently lost all power steering. What codes do I need to look for so that I can replace it with a 2nd hand unit tia Andrew
Model
500 lounge
Year
2012
Mileage
135000
Hi and welcome:)
Rarely anything serious, usually a power supply issue. Especially in winter
Before replacing any parts, have a read of this thread:
Hi and welcome:)
Hello and thank you.
I think first thing I would do is run a jump lead from battery negative terminal to engine block see if power steering comes back - this would point to earth cable issue
Then charge battery, or connect another battery if you have one, see if it improves
Those are usually the main two culprits
It's a popular mod to add an extra earth strap as the original is known to deteriorate over time
Hello and thank you i did put a code reader on it and it came up with code 1002
After seeing this I removed the column and sent bit away for repair however it's come back irreparable. What i need to know is if I'm looking to replace it what part number do I need to look for?
