Technical  Power Bleeding Brakes
Grimsby
Anyone got any experience using the power bleed feature in MultiECUscan ?
I am planning to renew the brake fluid on a my Fiat 500 and then I noticed that MES has a feature that uses the ABS pump to do it .
Is circuit 1 the front left/ rear right or the other way around ?
I know how to do it the conventional way pumping the pedal and using a pressure bleed kit connected to the reservoir cap
I thought I might try the MES feature and just wondered if any one else had used it and had any issues
Ive been looking at this, but Im not convinced its any easier. I did note you musy not activate unless the bleed valve is open. Try a simulation in MES.
I would presume 1 is FL - RR I would open both sides if in doubt. Only one circuit should drain. It seems a very short process so maybe equivalent to a couple of presses of the pedal? There is a MES user forum, maybe there is something in there.
