OEM ?
surely more air carnt make you lose power can it?
is it worth getting a bigger throttle body along with the induction and remmap?
if so which one
many thanks
ricky
OEM = Original Equipment Manufacturer ie standard
yes you can ultimately end up with less power as you can loose torque, more specifically you can loose torque lower down the rev range meaning the car can be slower in the real world
Closed loop fuelling means that the ECU will try to maintain the AFR at the target value but if your injectors don't flow properly then you won't see any benefts
