Hi people. After buying my second hand 1.4 Multiair I have suffer from low turbo boost. Maxing out at 25% it's caused three weeks of searching for the cause. MAP sensor changed, actuator movement checked by applying pressure, pressure measured from the boost solenoid valve... No improvement.
Then, thanks to the wonders of YouTube I added 3mm more pre-load to the actuator to wastegate. Bing! Boost works perfectly.
For the sake of that adjustment it has saved £s.
Please check this as a relatively easy try to fix before spending time and money elsewhere.
