Technical  Poor Starting And Running
ROB C
Hi, I have a 2001 Fiat Doblo 1.2 which when it eventually does start, from hot or cold, splutters and then runs very lean. The only code being logged is a lean mixture code. Ecu been tested and come back 100%, compression test reveals all cylinders good. Fuel pressure reads approx 1.7 to 2 bar..local Fiat dealer says this should be 3.5 bar? can anybody confirm this? Also the pressure does not hold and drops to zero when engine stops, could this be just a regulator problem? Help!!!!!
Frustratingly yours
Robbo
Hello there Rob and welcome to the forum (y) Unfortunately I'm not sure of the answer to your questions but I'll have a few words when I'm in work tonight with the fitter and see if he knows about the pressures etc.
In the meantime I'm sure someone else will be able to help you :)
