polys help
polys help
B
brewster
i had my polys out the car, i stupidly took the moter that adjusts the level of the beam off the lights, when i took it off a spring poped off. i assembled it back together and now it does not work properly, now one light will not adjust and the beam sits on the road, (useless) can anyone help me fix this ? cheerz ppl
yeh i put it back in the way it looks like it should go .. :(
The motor has a white prong on it with a type of ball socket at the end you need to push it properly into the light. Sort of up, down and twist it on. While holding the internals of the light with your fingers. Make sure when you hold the internals of the lights they are at there up most position.
Remove the covers from the light and see if you can move the light up and down with your finger. If you can its not in correctly. Its easier to fit the motors to the lights off the car. But its not impossible to do with them on the car, just take lots of time.
S
3
7K
Dark Lurker
P
10
832
Jason
J
A
1
555
Daniel
P
7
391
Ant Wells
A
3
1K
Tommy K
T
