So, noticing that the airflow in the cabin was not as high as I'd expect, I ad a look at the pollen filter on my 1.9 mJTD 16V manual Eleganza. Sure enough it was filthy. Even worse the manufacturing date on the filter is 10/05. As my car is an '06 registration, I must assume its the original fit. This is dispite 4 main dealer service stamps in the book. They had been in there as the plastic "push-pin" fasteners had been mangled. I can only assume they had just vacuumed or blown the filter with an airgun and put it back in
. I don't have the invoices or worksheets so don't know if the previous owners were charged for the part or not. Perry's want £45 for one!
I bought new Push-Pins on ebay, item No. 171487583943. Not the cheapest but seem reasonable quality.
I did take Photos so if any one wants I could knock up a guide, but it's pretty simple. Only thing to note is use a small coin to turn thr push pins, not a screwdriver, and don't press down. Basically turning the center pushes it up a ramp so you can grip the head and pull it fully up. The body may rotate, if so hold it gently with pointed pliers or similar.
Robert G8RPI.
Robert G8RPI.
