please help
please help
M
moz
i have a problem with my ignion on my bravo when i put the key in and go to turn it it does not want to turn at all. sum times it does but it takes a while to get it to after fiddling with it any advice on the problem would be very gratefully recived
If it's any help, my next door neighbout had this problem yesterday afternoon with his Citroen ZX and to make matters worse, the steering lock was "locked" on too.
Beleive me, it was a bitch of a job to sort. Anyway, to cut to the chase, a small screw had worked it's way loose inside the ignition barrel and after 3hrs of fiddling the brute force method was applied. We got the lock off, but will have to replace the barrel in the morning. I doesn't have a keycode immob, so I guess it's just a barrel and new key.
If you can get the barrel out, it may be worn and components have worked loose. Before you attack it, try a spare key?
Locksmith job - the barrel is damaged/ used to much
Eithe a new barrel or a fixing job
Members Site - - - - - - - My Site
G
576
garaint
G
B
2
528
Tommy K
T
T
3
736
Dark Lurker
