Technical  Please help!!! Coolant Problem
Pershore
Fiat Punto MK1 1.7D 1996
Ive noticed that the coolant is slightly creamy in texture. Why?
There is no pressure when I take the cap off the coolant bottle. Why? and the coolant is very cool considering ive just driven 150 miles!! why? Im not loosing water.
Please help and thanks in advance.
Ive recently had all belts replaced. The fan belt does squeal when i start her up.
Cheers for that I will have a look in the morning. Is the thermostat stuck open due to the coolant or old age. I will obviously need to replace coolant?
Hello again, I had a look this morning at the car and the thermostat is very awkward to get to, so took her to the garage and the guy said if its stuck open it wont harm the engine if i dont get it fixed!! is that correct.
How do i test the engine fan as it never seems to come on, even whilst waiting in heavy traffic. Is this due to the thermostat being open ?
You need to change your garage, if thats the standard of advise given.
If cars didn't need thermostats do you think the manufacturers would bother with the cost and complication of fitting them.
Diesels have less waste heat than petrol engines so need all the heat they can get.
SPD
Hello all, Ive just been quoted £100 from motor factor for thermostat but i must remove and send a pic before he sends me a new one!! Sounds abit pricey is it worth getting one from scrappy?
