Liquid Knight II
Established member
- Joined
- Sep 6, 2017
- Messages
- 735
- Points
- 171
So 2018 has been turbulent so far.
The MG ZT had a sudden and catastrophic water pump failure. Literally came from nowhere. The car was supposed to have been serviced last MOT but when the pump went it took the cam'belt, twelve valves and one of the head gaskets with it.
I had managed to save up for the retired Uno race car but had to replace the MG instead.
With this...
....mighty steed of a Rover 620Ti. As quick as the MG, smaller on the outside, bigger inside and as economical. Best of all a factory fitted dogs dick tow bar so I managed...
...to get the soon to be built Uno home at least.
Now the plan was to get the race car and build one as quick using the 1368cc 16V (98hp) engine from a Fiat Idea I bought for my sister last year.
I bought a set of wheel straps to get that home and the fun begins.
It was a tad wet when I pulled the engine out.
Phase 1 ditch the ecu, injectors and other ballast.
Ignition taken care of by the Uno distributor (using a knackered old Panda one at this stage) replacing the drive with an 18mm socket so I don't have to cut a locating wedge in the camshaft bolt. The original locator is too short and a standard socket too long. It would be easier to shorten and drill the socket than lengthen the shaft or weld a nut on the end of the bolt to meet it.
I'm thinking bike carb's for fueling. I have a set from my GSXR250R SP that'll be too small and from my old FZR1000 that are too big. CBR600 ones should do the trick. Having said that the ports are tiny...
...compared to any engines I have played with before so I guess a new base plate and fun ahead.
The Uno has a sunroof and I'm not a fan of those on track so before headed to the scrap heap the Idea had one more part to give.
Now do I use duct-tape or silicone?
@1:09 I think I'll weld it.
With this...
