Technical picture help needed PAS
sediciRich
Glasgow
Hello all, this is a request for pas pump union pictures, either actual or diagrammatic for right hand drive sedicivalvole 3 door. I have put my pas pump back on, but I have a mix up of unions and some with interesting shapes, I'm having difficulty in seeing how its all meant to look. A picture will tell a thousand words.
cheers
rich
Not exactly easy to take a picture of that!
I have a Dedra engine, rack and subframe etc out of the car I could photo if its any use.
Oh Rich, here you go
from a 1994 Tipo 16V 3 door
cheers steve, needed it a bit in the front of the rack to see the fittings shapes, no big deal the problem is the banjo 18mm I think on the zf pump, totally different from the coupe pump I have. Just another job on the list, I'll go to an industrial place to get one made up. Ho hum, just another day with the car.
rich
So you finally decided to keep your arms in proportion with your body, and re-fit the PAS? :D
I can't say I blame you. My sedici went through a phase of cutting out while the de-cat was fitted and boy.. it can be quite exciting losing the PAS as you zoom into a tight corner :eek:
Anyway I can assist with non-dismantled pics let me know.
