Permanent Live
Permanent Live
A
Adam
Anybody know of a permanent live, i need one for my nokia car kit?
nokia car kit
actually whilst i am on this subject has anybody fitted a nokia car kit in their bravo, if so where did they wire it too and got any pics of the install?
Re: nokia car kit
for a perm live, run a thick - ish fused cable from the battery (liek you would for an amp) but to around where the head unit is. while you are at it, you might as well replace the head unit's live feed with that one..or you can run a cable from the fuse box.
hope this helps,
Jay
Re: nokia car kit
Mine had one when i bought the car but had it taken out as i didn't like it. As far as where it was connected i think it was to the radio power but im sure there are more power wires in there that you could connect it too.
Joske
Re: Re: nokia car kit
I have one.
Use the same perm live that runs to your stereo :)
Re: Re: Re: nokia car kit
what colour wire is the permanent live on the fiat radio loom?
where did you mount the cradle?
Re: Re: Re: Re: nokia car kit
I used the wireing going to the glove box light when I was wiring in my snooper, seemed to work OK and was easier to get to the actual wires than the stereo.
Re: Re: Re: Re: Re: nokia car kit
is this wire a permanent live?
Re: Re: Re: Re: Re: Re: Re: nokia car kit
what colour wire on the radio loom is the switched live?
Re: Re: Re: Re: Re: Re: Re: Re: nokia car kit
its either the red or yellow.
i think you need the yellow for perm live, check with a test meter to be sure.
Re: Re: Re: Re: Re: Re: Re: Re: Re: nokia car kit
HELP!
I'm right in the middle of a big (for me) install. Am trying to find the same wires so that my new HU will keep a live feed with the ignition off.
Can anyone tell me what I should be doing with which wires please?
Cheers,
Marko
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: nokia car kit
i took a permanent live feed from the glovebox light but need a switched live?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: nokia car kit
does anybody know out of the three wires going into the ciggy lighter which one is the switched live.
black = EARTH
yellow (i think) = ?
White/blue (i think) = ?
S
5
443
Anonymous Coward
A
R
1
291
M
A
615
Auto-Media
A
S
13
219
A
