People with LEDs in there ceiling lights...
dont quote me on this (I havent tried it), but i think LED's in the roof light should dim in the same way as the normal bulb does, the controllers use PWM (pulse width modulation) to control the brightnes of the bulb, so it should work with LED's also.
Owen.
'99 Bravo GT TD100
I have tried it so i will quote you ^^^ mate.
36 super bright Blue Leds all dim to off nicly :)
"Old enough to know better, Young enough not to care"
Rapidly?
Did you check the video out. Seems fine to me. If it is quicker at dimming not that noticable and it doesn't cut off, it dims to darkness.
Joske
Joske mate, if it seems ok to youm then thats fine. they do go out rather quickly, but it looks fine to me. why get worked up over it?
Buzz
The champion of the Bravo 1.4
Owner of the Bravo 1.8
Member Page
Not getting worked up. Was just saying. Thats the problem with writing, you can't hear the expressions in a persons voice.
Not having a pop. Just thought Sven responded to the post without seeing the clip.
Buzz isn't your car a MK1? You wouldn't really live with the dimming light then would you or did paul r fit this to your Bravo?
All im saying it dims like normal. If you look at the reflection in the mirror you see it start to dim alot earlier than when you look directly at the light.
Joske
Surly the dimming part of this function is irrelevant, the fact that there is a delay that keeps it on is enough or am i missing the point?
It does not proove that LEDs dim, it just shows that the fixture is capable of dimming LEDs.
Not the same thing :)
I luv these posts when no one agrees :)
Studying electrical engineering at uni i would normally agree that leds cant be dimmed but looking at the video for all intents and purposes the leds are being dimmed. Not sure who i agree with now.
I'm confused and must go :)
Ghengis Khan, www.babarmalik.com
Having a masters in electronic engineering and over 10 years in the industry I know you can dim LEDs, but cannot dim them by simply varying the voltage as claimed earlier.
Re Arbarth Brava, The T shaped tool is for manually opperating the sunroof
C
7K
ChrisKnottIns
C
J
751
J
J
1
1K
Frank
F
