Technical PCB Help
Technical PCB Help
stealthtrooper
Hiya,
Just discovered this forum after buying a stilo a couple of weeks ago (also have a Ulysse). Any way on the stilo I've tried connecting my laptop using Fiatscan but just can't get it to connect. The multifunction display will show milage and outside temperature only and whilst the buttons on the dashboard seem to be working and beep when pressed the multifunction display won't work. Could these two problems be connected? Do I need a new PCB?
Any help would be apreciated.
Paul
Hiya,
Paul
If your using the fiatecuscan software you need to ensure that you are selecting the correct ECU type for your car otherwise the software will not know what to connect to.
I don't know much about the multifunction display I assume this is fitted to vehicles without connect nav ?
