General  passenger airbag
iScottyD
Hi all, just been out in the car and as soon as I started it it flashed up passenger airbag fault. As far as I know nothing has been knocked or moved about so don't know what could've made it all of a sudden come on. Is this a common problem or not?.
Airbag warning are nearly always bad connections, the heater blower is especially prone to bad connections stopping it from working, try the wiring tucked in behind and above the glove box, wiggle the block connectors as well.
In that case it might be my fault asi tried to disconnect the radio display earlier and might of pulled at the wire slightly. Oops....
Hi, I'm having the same probs with my Ulysse, Airbag Fault.
Passenger airbag deactivated and the 2 yellow lights keep coming on too. I've put the key in to activate it, turn the ignition on, no lights, 30 seconds then the lights come back on.
Any ideas would be great thanks
I can sell you one, it comes attached to the black padded strip that runs the whole length of the dashboard. It is not that hard to fit.
The other possibility is check the ecu under the carpet between the two front seats, it is not uncommon for water to somehow get into the well and corrode the wiring block connector and the pins of the ecu.
had the same problem last year it was the plug that goes into the airbag bought s/h airbag with the cable just used the cable fixed ok
