Sorry if this is a duplicate, but seems the first did not go through. Having issues with my 2008, 1.9 MJT, 8 valve. Cleaning cycle comes on every 50 km and if you are on the Autostrada, it frequently never goes off!
Once the car is up to temp if you are in 4th or 5th gear, power drops (3.300 rpm(max). Goes fast, just no acceleration.. No turbo boost when you step on the pedal! Turn key off andon and all is instatly fine. Loss of power does NOT occur if you are in the same drive but using Cruise Control. Does do a carbon burn however. Loss of power does not occur if you stay in 2 or 3rd gears up and down hills and curves on small roads until you slip into 4th. Key off and on and all is well again.
Fiat dealer is no help but am going back a third time in the am. Anybody have a clue?
Thanks in advance.
Thanks in advance.
