General Parking Lights
t
I realise is not a legal requirement to leave lights on if facing the right way but sometimes it feels the right thing - beats having someone hitting you on a dark street
hey aren't a legal requirement any more anyway, so there is no need. You must always park 'with' the traffic flow though.
it is a legal requirement and if not working an MOT failure..
249
All vehicles MUST display parking lights when parked on a road or a lay-by on a road with a speed limit greater than 30 mph (48 km/h).
[Law RVLR reg 24]
and it in full..:
Requirements about the use of front and rear position lamps, rear registration plate lamps, side marker lamps and end-outline marker lamps
24.—(1) Save as provided in paragraphs (5) and (9), no person shall-
(a) use, or cause or permit to be used, on a road any vehicle which is in motion-
(i) between sunset and sunrise, or
(ii) in seriously reduced visibility between sunrise and sunset; or
(b) allow to remain at rest, or cause or permit to be allowed to remain at rest, on a road any vehicle between sunset and sunrise
unless every front position lamp, rear position lamp, rear registration plate lamp, side marker lamp and end-outline marker lamp with which the vehicle is required by these Regulations to be fitted is kept lit and unobscured.
(2) Save as provided in paragraphs (5) and (9), where a solo motor bicycle is not fitted with a front position lamp, no person shall use it, or cause or permit it to be used, on a road (other than when it is parked) between sunset and sunrise or in seriously reduced visibility between sunrise and sunset, unless a headlamp is kept lit and unobscured.
(3) Save as provided in paragraphs (5) and (9), no person shall allow to remain parked, or cause or permit to be allowed to remain parked between sunset and sunrise-
(a) a motor bicycle combination which is required to be fitted only with a front position lamp on the sidecar; or
(b) a trailer to the front of which no other vehicle is attached and which is not required to be fitted with front position lamps,
unless a pair of front position lamps is fitted and kept lit and unobscured.
(4) Save as provided in paragraphs (5) and (9), no person shall allow to remain parked, or cause or permit to be allowed to remain parked between sunset and sunrise a solo motor bicycle which is not required to be fitted with a front position lamp, unless a front position lamp is fitted and kept lit and unobscured.
(5) Paragraphs (1), (2), (3) and (4) shall not apply in respect of a vehicle of a class specified in paragraph (7) which is parked on a road on which a speed limit of 30 mph or less is in force and the vehicle is parked-
(a) in a parking place for which provision is made under section 6, or which is authorised under section 32 or designated under section 45 of the Road Traffic Regulation Act 1984, or which is set apart as a parking place under some other enactment or instrument and the vehicle is parked in a manner which does not contravene the provision of any enactment or instrument relating to the parking place; or
(b) in a lay-by-
(i) the limits of which are indicated by a traffic sign consisting of the road marking shown in diagram 1010 in Schedule 2 of the Traffic Signs Regulations and General Directions 1981[18]; or
(ii) the surface of which is of a colour or texture which is different from that of the part of the carriageway of the road used primarily by through traffic; or
(iii) the limits of which are indicated by a continuous strip of surface of a different colour or texture from that of the surface of the remainder of the carriageway of the road; or
(c) elsewhere than in such a parking place or lay-by if-
(i) the vehicle is parked in one of the circumstances described in paragraph (8); and
(ii) no part of the vehicle is less than 10 m from the junction of any part of the carriageway of any road with the carriageway of the road on which it is parked whether that junction is on the same side of the road as that on which the vehicle is parked or not.
(6) Sub-paragraph (5)(c)(ii) shall be construed in accordance with the diagram in Schedule 22.
(7) The classes of vehicle referred to in paragraph (5) are-
(a) a motor vehicle being a goods vehicle the unladen weight of which does not exceed 1525 kg;
(b) a passenger vehicle other than a bus;
(c) an invalid carriage; and
(d) a motor cycle or a pedal cycle in either case with or without a sidecar;
not being-
(i) a vehicle to which a trailer is attached;
(ii) a vehicle which is required to be fitted with lamps by regulation 21; or
(iii) a vehicle carrying a load, if the load is required to be fitted with lamps by regulation 21.
(8) The circumstances referred to in paragraph (5)(c) are that-
(a) the vehicle is parked on a road on which the driving of vehicles otherwise than in one direction is prohibited at all times and its left or near side is as close as may be and parallel to the left-hand edge of the carriageway or its right or off side is as close as may be and parallel to the right-hand edge of the carriageway; or
(b) the vehicle is parked on a road on which such a prohibition does not exist and its left or near side is as close as may be and parallel to the edge of the carriageway.
(9) Paragraphs (1), (2), (3) and (4) do not apply in respect of-
(a) a solo motor bicycle or a pedal cycle being pushed along the left-hand edge of a carriageway;
(b) a pedal cycle waiting to proceed provided it is kept to the left-hand or near side edge of a carriageway; or
(c) a vehicle which is parked in an area on part of a highway on which roadworks are being carried out and which is bounded by amber lamps and other traffic signs so as to prevent the presence of the vehicle, its load or equipment being a danger to persons using the road.
From MOT testers manual:
"Lamps required by Regulations to be fitted to a vehicle to indicate its presence and width when viewed from the front.
They must show a steady white light to the front, or a yellow light, if incorporated in a headlamp which emits yellow light.
The light must be visible from a reasonable distance.
On vehicles fitted with dim-dip headlamp systems, the front position lamps must be checked for operation with the ignition switched off. This may involve the operation of a separate switch."
https://www.fiatforum.com/multipla/126484-parking-lamp-failed-mot.html
this law is written in the dark ages but I take it to mean that you are ok to park without lights if you are on the left .... "the vehicle is parked on a road on which such a prohibition does not exist and its left or near side is as close as may be and parallel to the edge of the carriageway."
Nice view by the way Maxi - I would only leave my lights on if it were too dark for you to see this
If i turn the lights ON after i pull the key out of the ignition, I will have parkingslight for as long as the battery can hold power. But i also live in a country where its required to have the lights on at all time.
I had a play today and parking lights turn on if you switch the light switch after the key is taken out of the ignition
249
[Law RVLR reg 24]
So does that mean you should leave them on overnight? Would that not drain the battery?
Yes in theory - to go by the letter of the law - if you are not in a 30 zone AND it is not street lit AND you are facing the traffic flow (ie parked on the right) AND parked on the road (ie not in a parking space) you must leave lights on
The easiest way to avoid this is to always park on the left then your reflectors are deamed to be good enough
