Panda 2012+  Pandinha
My first and hopefully last car
This is my beloved Panda. She's some kind of weird mix between a Panda and a Pandina. I suspect the factory had run out of normal Panda parts but still wanted to make the last batch of Pandas.
It has got Pandina: seats, rear quarter windows, and the digital dashboard. The rest all seems to be from the regular Panda.
Hey all,
After months of research, a lot of which had to be done based on Abarth/Fiat 500s because they have more online content, I decided to start working on making my Panda quieter. I want to limit a bit the road noise, to have a bit of a more comfortable drive.
About the materials, I decided on a layer of CLD (1.5 mm alubutyl) on the metal, and a layer of Reckhorn DV 10I sound isolation fleece (to absorb instead of deflect sound). I avoided MLV due to weight.
I have so far done the two front doors, the rear right door, and I applied CLD to the trunk door and under the hood. I'll try to finish the last door this next week, and add fleece to the trunk door as well.
I can already notice some differences in city driving tho, including "small stuff" like the noise the window motor makes, how the speaker sounds, and how the door "thumps better" when closing. After finishing the last door and trunk I'll try to go on a longer drive to see if I can hear any improvement.
⚠️ Disclaimer: I am not a professional, and I do not actually recommend doing this to your car. You would probably void warranties, or potentially introduce water ingress, or potentially break parts. I will not be liable in case you damage your car or anything else bad that happens . This is just for educational purposes, and/or for other people who are trying to sound deaden their car and might find my experience useful in some way.
These are roughly the steps I followed when working on the door:
1 -> Remove plastic covers on the door unlock and pull handles, and remove the screws (M5 hex on mine). The front doors have two additional screws on the side of the door lock (phillips, threaded onto plastic). The window crank needs to come off on the rear doors. You can use a microfiber cloth for that, there are plenty of videos online of that. Careful not to lose the clip that holds the crank in place! Additionally the front doors have a plastic trim where the mirror adjustments are, these can be easily pried off with a plastic trim tool.
2 -> Carefully pry the door card away with plastic trim tools, carefully unclipping it. You should consider grabbing some spare clips if your car is older, as the plastic becomes brittle over time. The clips are on the two sides and on the bottom of the door card.
3 -> The door card hangs on top. You need to "slide it up" to unclip it. The part it clips onto might come off with it, it's just the window rubber seal, just put it back on the door if that happens.
4 -> Next step is disconnecting the door lock actuator. It's hard to describe this, so try watching a youtube video. After that the door card is finally free, but make sure none of the clips remained on the door.
5 -> ⚠️ This step is not reversible! I am not suggesting you do this and I won't be liable if you damage your car! The vapor barrier (white foam) needs to either be cut to allow working, or needs to come off completely. I imagine resealing it with tape would not last for long or would not be water tight enough. I decided to remove it completely and make a new one. The removal is pretty easy to do either by hand or with a scissor/blade, just be careful with the paint.
6 -> Now that the vapor barrier has come off, you also need to remove the glue (or maybe it's also butyl? idk) that held it in place/sealed it. My car is relatively new and this was pretty easy to do. I simply started pulling the material, and it seems to lose its stickiness when stretched. It would occasionally break as I was pulling it off, but I would just "restart" pulling it when that happened.
7 -> Clean all the surfaces where you intend on applying CLD. I used brake cleaner for that. Be careful not to strip the window rail or other moving mechanisms from grease.
8 -> Apply the CLD. Larger sheets are usually more effective than smaller sheets put together. I went for almost full coverage since the door panels have pretty good access. The doors are much heavier due to this.
9 -> I applied CLD around the speaker too because I wanted to make sure water didn't leak from the mount.
10 -> Time to make a new vapor barrier. Make sure the surface is clean with some brake cleaner. I replicated the factory seal with butyl rope. (6mm, 8 meters was enough for all doors). You can stretch the butyl rope as you apply, so that it is not too thick.
11 -> I use the door card to cut thick plastic sheets to roughly the same size. I then start sticking the plastic sheet to the butyl rope on the door, starting from the bottom.
⚠️ It's very important not to let the plastic sheet fold when sticking it to the butyl, as that might allow for water ingress. It was inevitable that the sheet folds, I just tried to ensure it folds on the top part, instead of on the bottom where the water drains to.
⚠️ You also need to make sure that you have enough slack since parts of the door card protrude "into" the door.
⚠️ You need to make two cuts to the sheet, to route the speaker cables and door lock cable out.
12 -> I cleaned the door card on the inside, and applied some sheets of CLD. I went light since I don't think plastic resonates too much.
13 -> I installed the insulation fleece to the door card, being careful so that it isn't applied too thick. I tried to keep it lower or at the same level that the clips are, to prevent fitting issues. I also kept the areas around the door handles clear, where the screws are.
14 -> I added some 2x5mm soft foam tape to the door to prevent it from rattling, around where left/right and bottom edge of the door card. I also added some 1x5mm foam tape to where the clips are retained, to prevent them from rattling.
15 -> Time to reinstall the door card. You just need to do the reverse of what you did when removing it. I had issues with one of the clips, where it simply refused to clip in all the way. It had deformed and was not "springy" enough to remain clipped in. I also had an issue where one of the doors came with a clip missing.
16 -> Screw the screws, and install the crank again.
Some pictures:
Right front door stock vapor barrier.
Left front door vapor barrier after removal, glue still in place
Right front door replacement vapor barrier.
Right front door card, with alubutyl applied
Right front door card, with fleece applied
Right rear door with vapor barrier removed
Right rear door new vapor barrier
Right rear door card, with alubutyl applied
Right rear door card, with fleece applied
Trunk door alubutyl
Add 3m stick on door secodary seals. They cut noise (mainlymirror noise) and keep muck out of the door jambs. Road noise is a problem but the subframe is hard mounted so not easy to stop.
I have been thinking of that. I'm still strategizing what size of weather stripping to get, and where to apply it (door or car body). I will post an update if I end up doing it.
Great post and really useful photos. Could you save as a guide? I xould do this and credit you as the author if not?
Thanks for the encouragement! I was thinking of writing a guide, but I want to finish everything first to make sure I know what to do with the trunk door. I also wanted to write some "smaller" guides (like how to remove the door card) and refer to them on the noise isolation one. Gotta see how much time I will have to do that.
Another thing is that I have been waiting for rain, to make sure that the new vapor barrier works well. It's not worth it making a guide if what I did doesn't work.
I have decided door bottop might work on tge frobt but cleaning would be harder so I thing thus is right. Keeping door jambs clean is reallt nice. Doors shut with a nice thud now.
My door seal was Hot 2m D x79" I cant see any identical at the moment and its out of stock so eBay wont let me post a reference, I have a bit left and will send a pic. Its cetainly small. Simple D section and the smallest available. I have ahd to add Evo Stick on some bots to refix. My car is so well sealed and polished it does come off occasionally. TYHis glue does not affect the paint and could be easily removed, at least from my paintwork. You ned a lot to do all the four doors. I dont think you can do the tailgate.
I did quite comprehensive sound treatment/damping on my Cross right after I bought it in 2016. Did the sandwich (butyl, ccf, MLV) and filled every hole (yeah!) with 3M thinsulate. I treated the doors for stereo and enlarged the speaker hole to fit 8" midbass drivers. My thought was to make the Panda as quiet as a BMW 5-series.
The deadening works really good when you get the coverage of MLV (which is what moves the needle to block noise). I drove around a whole winter with an exhaust leak without knowing until summer when I drove with the windows down.
Unfortunately, the Panda will not be as quiet as premium germans, due to the windows (glass) is not laminated with sound dampening film as the more premium cars are. The wind noise at motorway speeds are still there through the glass. I also have stick on D-rubber seals in door openings to block more wind noise coming in through the doors.
If you are contemplating dampening the roof, I recommend pulling the liner down and tacking some butyl on the panel and filling the whole roof voids (lots of air volume) with thinsulate or similar). It makes the atmosphere inside more "dead". You can almost not hear the rain on the roof anymore either. I didn't go for MLV above window height.
