Technical panda revival woes
fettlerwal
hi again all . got panda running ok after long layup new head gasket and belt , mot man said weldin and horn not working so not that bad ........but no oil to cam now !!! have i put gasket on wrong or is there a fault help pleeese
It is possible to put the gasket on the wrong way so thats probably your problem unfortunately(n)
Which way the tab sticks out now? (bottom left)
tag looks good could it be a blocked oil way after standing so long , starting to loose the will !!!!!!
Try it without the gallery pipe just to check if the oil way is clear, blow throught the pipe as well.
Use biger size flat blade screwdriver and pice of cloth to prise it out.
Does the oil presure ligth goes off?
Keep the faith!
hi all i think i dropped one and put the gasket on wrong , live and learn i guess . where is the cheapest place to get new head gasket and stretch head bolts . cheers
