Pandamania08
Hi everyone,
This is my first car, so please don’t judge — I’m trying to learn and understand what’s going on.
In early 2026, I did an engine oil flush on my Fiat Panda 2004 1.2 169 axb 44kwh.
A couple of months later, I started noticing several problems:
Gradual issues after the oil flush
The car couldn’t reach the same top speed anymore
Acceleration became noticeably weaker
The average fuel consumption display stopped working and only showed -- --
The car still started normally during this time
Burning smell
Around November, I started smelling a burning plastic / oil smell:
The smell came through the heater
It was strong when stopped at traffic lights
The smell disappeared while driving
This happened repeatedly
Oil leak (long-term issue)
I’ve had an oil leak for a long time
I recently identified the main source as the valve cover gasket, leaking from the top of the engine
Oil is dripping down onto components below
Breakdown – No start
A few days ago:
I drove about 100 km round trip in the evening
The next morning, the car would not start
Current symptoms
Starter motor cranks strongly and at normal speed
→ Battery and starter motor are OK
Engine does NOT start / does not fire
Fuse box checked — nothing blown or damaged
I checked wiring and found damaged / exposed red-green wires under the engine
One component under the engine is completely drenched in oil
I believe oil contamination may have caused a short circuit
I manually pressed the fuel inertia switch under the seat — no change
My current conclusion
The engine cranks but does not start
This points to fuel or ignition being cut
Most likely causes:
Fuel pump power cut
ECU / sensor signal interrupted
Short-circuit caused by oil leaking onto wiring
The exposed red-green wires under the engine seem suspicious, but I don’t know the name of the part they belong to
What I need help with
Identifying the oil-covered part under the engine
Confirming whether oil leakage could have caused this no-start condition
Advice on what to check next (sensor, fuel pump, wiring, ECU, etc.)
any help would be greatly appreciated
thanks in advance
Any help or guidance would be greatly appreciated.
Thanks in advance.
Burning smell
A few days ago:
Current symptoms
Most likely causes:
Fuel pump power cut
thanks in advance
Thanks in advance.
- Model
- panda 169 axb1a 1.2 44kw__ 4-door
- Year
- 2004
- Mileage
- 197000
car start 1 failure.mp418.2 MB
