Technical Panda not starting on all cylinders.
beermouse
After an hour of motorway driving, I stopped for a few minutes to shop. When I tried to start the car again, it shaked badly, ran unevenly and sounded strange, and pretty much all dash lights stayed on. I let it cool for 20 minutes and tried again - this time it ran smooth, no shaking or strange sound, but the yellow engine light stayed lit. Since it wasn't a red light, I drove the last km home, and all felt as it usually does.
Looking under the hood, I noticed what might be a leak in the breather hose:
Could that give those symptoms, or is something else going on? Is it something easily fixed? I'd like to know before I give a mechanic direct access to my bank account :oops:
Model
169 Panda
Year
2009
Mileage
200000
There will be a clue here
But we need to know which lights remained on
Read the code would be a first logical step
Worth checking if the MAP sensor is covered in oil
It's only held on but one bolt, you can leave the wire connected normally
I know, but memory fails me as I turned the engine off quite fast
Today, after having started it about 5 times, no lights are on, it runs smooth, and there doesn't seem to be anything coming out the crack in the hose
I don't have access to an ECU scan, unfortunately
That would require me taking the air filter and box off, right? From what I can google, it seems the MAP sensor has been in a bit of places over the years, as has the design of the breather hose - mine is the 60 HP from 2009.
Could a temporary fix be to wrap the hose with some TESA selfbonding tape or such? My main objective is to keep the Panda running until MOT in October, and have it fixed properly then if everything else passes.
No you don't normally have to take the air box off, especially if it's on the left side, if facing the the engine, electronic throttle body
It's on different sides of the inlet manifold, depending on whether electronic throttle body or cable
Thank you - I found it, and it looked good I think? - a thin layer of oil, no build-up of anything.
Yesterday the car started fine when cold, and very rough when hot - today, again fine when cold. I taped up the crack in the hose with TESA self-bonding tape, and it has now started fine twice when hot. Is that pure luck, or could I have found the reason? And if so, is it possible it will last until October?
Engine good cold but rough hot is often a coil issue. It has two coils each firing two plugs at the same time. A weak coil will often drop one plug before it finally gives up. You need to get an OBD scanner to read the codes. They are not expensive.
If you need them, new coils are about £30 a pair** from Shop-4-Parts. https://www.shop4parts.co.uk/?name=store&op=Product&ProdID=987 Ask them about the coil seal.
** Fit a pair, because the other coil will soon fail.
I remove the battery box and ECU because it gives much better access. But you "can" replace the coils without doing that.
Only time will tell
As long as it stays air tight it's fine, done similar myself until part arrive and been fine
When it's running rough will it still drive up a slope
Does it fail when diving and gets hot, or only when restarted from hot
That's true. And if the coil is bad you need to replace it as soon as possible otherwise it can damage the ECU. Bad coil makes shortcut inside and that can toast the ECU transistors, ECU being just upstream coils.
Cool it telling you you have a problem with the coil or wiring to the coil that goes to cylinder 1
If you have 2x coils on the right hand side of the cylinder head, you only need to replace the faulty one
There usually a reason for the coils to fail
Normally it because of a misfire due to the spark plug gap is to big occasionally due to a fault HT lead, if the HT can't find an easy path to ground, eventually it tunnels under the coil
I only replace the faulty coil and plugs, never had the other fail,
