Technical  Panda door part numbers
Redpedro
Scotland
Hello
I have just acquired a Panda cross with a damaged drivers door. I have been offered a door from a standard 4x4 in the same colour, but I am unsure if the doors are the same only with different plastic trims?
I have tried the part number search on here and it seems there are various part numbers, but after market doors available are all the same and it says you need to cut your own holes for fixing external trim
Many thanks
Model
Cross
The doors are the sames size and shape. Most trim is stuck on with double sided tape. I dont know about the Cross as my waze has trims more like the standard 4x4. If you have to drill for clips measure three times. Make a full paper template before drilling, and treat the holes with cold galv spray.
