smokeme
Established member
Yeah, fair enough. The modern FIRE turbo engines make what you were trying to do to FIRE engines years ago child's play now. And if you know simple electronics, they're cheap to implement too! I just put one in an Uno for £700.
not really, most of the information i gathered at the time is still useful today and 200bhp per litre still requires skill to achieve. the only difference nowadays is that most people do it for bragging rights while i did it as a research project into unexplored territory..
The 16vt engine and gearbox is huge and not really good for a Panda.
Well, dont get me wrong, it is possible but you need a lot of time and fabrication skills. Plus you need to be able to completely destroy your Panda - so make sure its rotten and worthless first!
Anyway here's the dilemma with the 16vt.
The distance from the side engine mount to the gerbox mount is the same as the distance between the top of the Panda strut towers. So just the 16vt engine and box have to fit where usually your Panda engine and gearbox is already mounted with driveshafts. To overcome this you need 4 inches extra width (at each side) in the engine bay, which means moving your strut towers, which means re-aligning your car etc etc AKA not much fun anymore.
Another problem is that if you managed to do it another way like cut the engine into the R/H wing and sit the gearbox in the same place as the Panda gearbox, the final drive would stick out so far that you probably wouldn't be able to get 1/2 a turn on your steering before it hit the final drive.
Then I realised that I was going to get 250bhp from all this effort when a good U/T or a Punto GT engine conversion could get the same power with half the weight and half the effort.
Now if anybody has any good ideas about brake upgrades I'm listening.....
Smokeme, tell me about your Panda. What power did you put through it? How did it bend the chassis?
250bhp for a 16vt is easy to achieve on a stock engine, just cranking up the boost will get you more then that on a stock series 2 thema, the coupe with a more advanced ecu will only require a chip.. stock internals will hold about 320bhp, forged and the wallet is the limit
my panda had a 999cc 8v that suffered a few alterations, basically forged internals and turbocharger.. last test went a bit over 200bhp before i removed the engine from the car, self imposed rev limit was at 8000rpm but it would go higher, total run time for the project was a bit over 10kkm.. engine has no signs of wear and when i find a suitable chassis it may get another chance.. all of that going through a stock 750cl 4speed gearbox that only had shotpeened internals, the engine would hit 8000rpm in 4th gear a bit over 200kph faster then a stock panda get to 100kph..
had serious problems with wheelspin, even with slicks it would spin in 4th gear over 4000rpm if the throttle was floored..
it was a fun project, not very fuel efficient, very hard to run it at the limits but worth every minute i spent on it.
