Technical Panda 750 CLX – 91 lacks power when hot
This sounds more and more like petrol starvation now you say its when you have a hill to climb check fuel line back to tank. If you have filler cap off you should be able to blow the petrol in the pipe back its not a long pipe run. Could also be petrol pump not strong enough to feed carb when you demand petrol for the hills. Does it run pull ok on the flat? if you gas up does it take its time or does it take up the demand for speed?
Thanks Allen:
I`ll try that tonight, but i m worry about the sound the engine does when problem arises (after 30/45 minutes running) ... like enngine is making great effort to move the car, like something is seized...not very clear right?
like when u scratch 2 metal plain surface against one another smoothly, again...not very clear right?
Its more dificult to run uphill then in a flat...
At idlle if i depress the clutch and accelerate the cars sounds completly normal, only when engaging a gear the car sounds funny.
Also at idlle, clutch depressed, if accelerating suddenly, the rpms seem to take quiete a lot of time to come down.
Paulo -Alterlego
And guys, i think i`ve read all the posts and all the threads concerning the classic panda, by the way, it was a diy post about changing front wheel hubs that gave me the strenght, the capacity to go ahead and change the transmision gaiter on my on, i`ve learned a lot here... (even improved my english...cof...cof... its been a while not using it...).
And now for something completely different...
After asking for advice in Italian cars club (w/ another avatar)
I say: britains rule!!!
(y)
I wish I could hear or drive this panda:cry:Does the engine rev fast up hill but slow speed on car? Does your car make any horrid noise on flat smooth road or drop in engine power?
