Hi everyone,
I’m having a strange issue with my 1988 Fiat Panda 141 1000 i.e.: whenever the engine is idling and I press the brake pedal, the engine stalls immediately.
What has already been tested/done:
Possible causes I’m considering:
What I would like advice on:
Any tips are welcome — thanks a lot for your help!
- Vacuum leak ruled out: brake booster and non-return valve checked → both seem fine.
- Brake light circuit ruled out: I disconnected the brake light switch and tested again → problem persists.
- Idle control valve replaced → no improvement.
- TPS (throttle position sensor): possibly not giving a proper idle signal or has worn tracks.
- MAP sensor / pressure reading: may not be reacting correctly to the sudden vacuum change when braking.
- Grounding / voltage drop issue: poor engine-to-chassis ground could be causing ECU/ignition to cut out.
- Best way to test and adjust the TPS on this Panda (expected voltages and pinout).
- How to check the MAP sensor (whether external or ECU-integrated) during idle + brake application.
- How to measure grounds/voltage drop correctly (test points and acceptable values).
- Any known weak points in the IAW ECU or wiring on this model that could explain this behavior.
- Model
- 4x4 1000ie 33kw
- Year
- 1988
