minimotokid1990 New member Parked in the garage Joined May 20, 2012 Messages 35 Points 14 Location Chesterfield Aug 26, 2013 #1 Does anyone know if you can put 500 abarth srings on a panda 100hp. Even if its just the rear ones or the front ones. Thanks mark
Dev100 Member Joined Jan 3, 2013 Messages 380 Points 70 Location Preston Aug 26, 2013 #2 Yes you can but they don't reduce the height any and aren't as firm as pandas.
OP OP minimotokid1990 New member Parked in the garage Joined May 20, 2012 Messages 35 Points 14 Location Chesterfield Aug 26, 2013 #3 Ok thank you I am after making my panda 100hp abit lower and is on a budget. What do people think
Dev100 Member Joined Jan 3, 2013 Messages 380 Points 70 Location Preston Aug 26, 2013 #4 H&R springs are £150 odd. Shockers 3-600 depending on what you get.
1.8Stilo Prominent member Parked in the garage Written a guide Joined Oct 18, 2004 Messages 3,650 Points 610 Location all over the place Aug 26, 2013 #5 Get some spring compressors and change them yourself then you've saved on the Labour charges as its quite a simple job.
306maxi STOP! Hammer time! Joined Mar 3, 2008 Messages 24,547 Points 3,703 Location The Welsh Riviera Aug 26, 2013 #6 They would massively screw up the handling.
Dev100 Member Joined Jan 3, 2013 Messages 380 Points 70 Location Preston Aug 27, 2013 #7 306maxi said: They would massively screw up the handling. Click to expand... What would?
306maxi STOP! Hammer time! Joined Mar 3, 2008 Messages 24,547 Points 3,703 Location The Welsh Riviera Aug 27, 2013 #8 100hp springs and 4x4 dampers
Rmdinho Patron member Joined May 21, 2013 Messages 228 Points 53 Location Thornton Aug 27, 2013 #9 306maxi said: 100hp springs and 4x4 dampers Click to expand... Who said anything about 4x4 dampers?
306maxi STOP! Hammer time! Joined Mar 3, 2008 Messages 24,547 Points 3,703 Location The Welsh Riviera Aug 27, 2013 #10 Sorry my bad, got confused with another thread. My apologies!
