Technical Panda 08 - Passenger electric window not working.
Southport
Wotcha!
As the title, I hear a single click (which sounds like a relay engaging?) from the centre console when I press the button.
The window does not move, and there no other noises.
The drivers side works fine.
What should I be looking at first?
Kronface.
Model
5dr Diesel multijet
Year
2008
Mileage
111000
New regulator. It sounds like my 100HP. Both failed in quick sucession. Thankfully its not a hrd job. If you can get the door card off you can try supplying power directly to the motor, you will be able to see if it works and if anything else is not working or broken
Ta for the info.
Pulled the panel off, only snapped 1 clip on the small cover by the handle.
Kinda impressed at the success rate.
The click is definitely coming from behind the foam soundproofing.
Does that help identify the issue any further?
