Technical palio mods
bullspalio
Hi everyone,
I;m from south africa and own a 1.2 palio
can someone please help me with any engine mods to a palio 1.2
I need to get n few kw out of it or maybe get n 1.6 if it will fit.
I was thinking of a T2/3 turbo maybe but I dont know for how long the motor will handle it.
Bullspalio
Hi i am also fron SA did u found out some of ur awnsers please let me know
i also have a fiat palio 1.2 mpi EL 2001 modle. And have fitted a Preformance air filter and implemeted a freeflow system my next step will be branches would that be whise? and would that give me any more preformance? if so how much?
Hey guys i am also from South Africa and have a 1.2 2000 blue palio ED. It seems we have the same problem when it comes to mods but at the mo i just want to know where the fuel filter is so that i can replace it when i try and service my car. heehee. I also know of a site that might help you guys a bit called maxmyride.co.za they have all sorts of stuff from body mods to audio and engine upgrades for all vechile types i think.
Hi
I also own a Palio 1.2 5 door. Im from South africa. I have a 2004 model.
I have also tried endlessly to get help on mods, but no1 seems to know or wants to help with a palio.
I have added a performance filter and a free flow system from Powerflow.
The tone is wild as hell, but performance has increased a little, not too much tho.
Im running a full Kicker audio install so i guess that has added weight, plus soundproofing in the doors.
I am looking at adding a UNICHIP so that i can take full advantage of my freeflow and filter.
does any1 have any thoughts?
My mechanic simply hates my car, to open the door panels, we had to make specialised tools.
its been a week now and i still cant find out where the Fuel Filter is located. Does any1 know?
Hi there, also from SA,but drive a 1108 uno,is this a SA only post as no one else seems to post here.
Well it's a 1242 FIRE engine, and your best mods would be to take off your head and skim it about 0.6 mm, get the head gasflowed, ported and polished and grind the cam 288 deg, along with your intake manifold. this mod would give you the most of power on a N/A car. then you can fit an induction kit and a branch and freeflow.
and when you finished all these mods send it for a dyno tune.
These mods should set u back roundabout R5000 - R8000.
Camtec in JHB do good jobs on cylinder heads, they quoted me R3000 to port,polish,gasflow and sort the cam for me.
dizzyJ said:
Hi
what lame mechanic do u have,Fiat is the best car to work on for me,easy to work on etc. I'm a mechanic at merc, and use to work on Mitsubiishi and jeeep and VW. and they are **** compared to working on fiats
The fuel filter is directly under neath the feul tank there is a few crapy screws there that you need to undo but it is there :)
give me your email adress and i will mail you a pic of my palio :eek:
heys guys watsup
i have a fiat palio as well.
for the computer chip dont go with dastek yet as it is very problematic with the fiat palios.
they say it should be sorted in about a month.
the production series race fiats use a gotech fuel managment system.
this adds about 10kw- 15kw if tuned properly.
Dam at least im also not the only one who battles with the door panels. ha ha ha:rolleyes:
Hi Guys
Gr8 to see Fiat Palios 1.2's modded, if you guys want parts let me know as I have modded my car and it took me while but i says its worth it.
All parts from engine to body, sound & interior
Look at attached pics.
Oh and also we get the car here with rear drum brakes so do you have any info about a rear disc brake conversion, and excuse me for my questions but i really want to start the making of a special car here :D
Hi there.Dont know if punto 1.2 bits will fit a palio motor but got to be worth a look.There is allsorts of stuff to tune them.
bob3825 said:
hey Space-Ind. i have a 2006 fiat palio and i was hoping to find some aftermarket suspension for it, so do you have any idea about this?
the best place for springs for a fiat palio depanding on how low u wanna go just let me know and what model (if ur in south africa) just mail me
[email protected]
Hi space-ind. Where did u get those tail lights from or are they sprayed? They look really nice.
As for the turbo question someone posted, Gassed who just joined the forum yesterday is in the process of fitting a turbo to a 1.6 Palio motor. His current Uno with a Uno Turbo motor is one of the fastest in South Africa if not the fastest and does a quartermile in 12s! Should be something to look out for.
My Tailights are sprayed, thanks for the compliment.
Turbos can be fitted to Palio 1.2, i am in the process of doing the conversion, trying to do it all for under R 7 500.
I used the tail light spray from Autostlye or you can use tamiya smoke spray (can get it from and hobby shop that sells R/C cars)
Cool, i did think of the Tamiya one as i used to be a keen model builder, i just thought there might be one designed specifically for the purpose.
