Technical P0238 on new Ducato
Ducato180
Islamabad
Hi everbody
I have a Ducato 2.2 250 2023 and I am getting now the P0238 + limp mode on every hill, even on just moderate upward slopes. After a couple of 100kms on the same day it is so bad that even a slight acceleration from 40 to 41km/h on a flat road will result in a P0238.
On the next day with a cold motor it is okayish, the P0238 only showing when doing a decent acceleration, but as the day continues it is getting worse and worse.
It is not accompanied by a P0401, indicating a clogged EGR, as I have read on threads about P0238 with older models.
I have deleted the DPF (physically removed it's interieur) some 20.000kms ago. Something must be clogged because of that. So far I've checked LP-EGR cooler, Diesel filter, air filter - all seemed okay to me. Haven't checked the HP-EGR so far, that is the next on my list.
Any thoughts on that?
Thanks a lot
Model
Ducato 2.2 250
2023
Mileage
27000
when you say you 'deleted' the DPF, did you re-program the ECU to account for it's removal? I understand that's what 'delete' usually means. If you didn't, it would make sense that faults are occurring.
This new ECU is not re-programmable, so back then I disconnected 5 major sensors and simulated them. This setting worked fine for 20.000km
Thanks, I am in the process of working through those 90+ pages. From what I understand it is mainly about 1. older vehicles and 2. accompanied by some P0401, P0402, ..., which indicates some malfunctioning EGR.
Some later posts refer to Euro 6 and some differences. I do not know of any public docs for the 2.2 which was approx 2022 to 2024.
In answer to your last question. Sorry but who knows? Could be sticky 🦋.
Interesting to see if you get a solution but I have no ideas other than a complete strip. If not mechanical, 🤬.
