500X 1.4 Turbo MultiAir Air leakage In turbocharger (Signal compare failure) P0236-00
Component Concerned = Air Intake Pressure Sensor
Connect the diagnosis equipment to the Powertrain Control Module and check that the value of the "intake pressure" parameter is 300 mbar with engine warmed up
Check for the presence of penetration/leaks in the intake manifold
Check the correct position of the throttle body on the intake manifold
Check that the operation of the intake pressure sensor is correct.
