Hey,
I've mk2 punto 1.2 8v, last wk when starting up the air blowers remained cold (on the hot setting) even though the engine was warmed up and the engine was ticking over a bit funny, chugging abit, like it was out of timing, later in the journey the engine started to overheat, pulled in and switched it off the engine, left the battery on (the fan had kicked in once past halfway as usual) checked the coolant lvl, nd it was fine, eventually (several stops/cooldowns later) got home. I have now flushed the system, replaced the thermostat and refilled with coolant and bled the system. was working fine for a day nd :bang:
now the wierd thing is (engine still chugging) that its still overheating blowing cold air until I Rev (engine stops chugging) bout 3000rpm nd the blowers get nice nd hot nd the engine doesn't overheat, leave it sit back to idle nd the blowers go cold again. wats goin on? I thought it was air pockets but have bled it several times now until fluid flowing out. my next thought is that its the water pump, its driven by the timing belt is it? or is it just in the way, none the less any pointers you could give me would be great! HELP! thanks
Dev (newbie)
Dev (newbie)
