So after i changed my master cylinder with new i also replaced rear drums, (this was the last part of the car i think i had to replace with new)
. Braking is much better than before but i am dealing with two problems. When i hit the brakes hard, nose of the car with blocked wheels goes straight but tail wants to turn to the left. Also i have noticed that rear drums got very hot and especially the left one. At the same time front drums are normal to touch. I have changed the drums but not the pads since they are new and have checked that retaining springs are in place, cylinders moves with no problem when i apply the brake with drums off the car and hydraulic fluid has a normal flow during bleeding so no blocked line here. In general all brake parts are new. Also rear wheels turn with hand almost free and i put the drums in place with almost no problem since i reset the springs that auto-adjust the pads. Is it normal for new drums to overheat for the first kilometers of use or there is something wrong.
