1 1 Peaky Blinder New member Joined Oct 26, 2013 Messages 5 Points 1 Feb 11, 2017 #1 what will cause over fueling problems ? This is on a Fire Proof engine Answers on a post card . Last edited: Feb 11, 2017
Peter Pick-Up Patron member Parked in the garage Joined Mar 15, 2008 Messages 5,116 Points 1,121 Location Netherlands Feb 13, 2017 #2
OP OP 1 1 Peaky Blinder New member Joined Oct 26, 2013 Messages 5 Points 1 Feb 13, 2017 #3 OK will be more specific. The car starts fine but when warm it will send black smoke out of the exhaust when you rev it.Also it seems to consume more fuel than normal. So any pointers,It has recently had a HG change.
Peter Pick-Up Patron member Parked in the garage Joined Mar 15, 2008 Messages 5,116 Points 1,121 Location Netherlands Feb 13, 2017 #4 What engine? Petrol or diesel?
OP OP 1 1 Peaky Blinder New member Joined Oct 26, 2013 Messages 5 Points 1 Feb 13, 2017 #5 Sorry it is the petrol engine
Peter Pick-Up Patron member Parked in the garage Joined Mar 15, 2008 Messages 5,116 Points 1,121 Location Netherlands Feb 13, 2017 #6 Any detected faults? Did you read the ECU yet? http://www.ebay.com/itm/Popular-MS3...:g:un4AAOSwYIxX5W-S&item=172352221300&vxp=mtr This post contains eBay links which may earn a commission at no additional cost to you.
OP OP 1 1 Peaky Blinder New member Joined Oct 26, 2013 Messages 5 Points 1 Feb 13, 2017 #7 Er no not yet,It is an early Punto so will it have OBD fitted.I think it is a -97 ish model.
Peter Pick-Up Patron member Parked in the garage Joined Mar 15, 2008 Messages 5,116 Points 1,121 Location Netherlands Feb 13, 2017 #8 Could be the 3 post connection OBD, Fiat's own design.( so the Maxiscan is of no use...) So see a dealer to have the ECU read first.
OP OP 1 1 Peaky Blinder New member Joined Oct 26, 2013 Messages 5 Points 1 Feb 13, 2017 #9 Ok will have to have a look.
portland_bill Patron member Joined Feb 22, 2004 Messages 10,771 Points 3,344 Location Faringdon, Oxfordshire UK Feb 14, 2017 #10 Usual causes are ignition misfires, or temp sensor showing colder than true temp.
