Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 3,471
- Points
- 945
In clarification of Hugh's post, the buzzer is wired in parallel with the step (retract) relay coil. The fact that the buzzer is not working suggests that the step relay is also unlikely to be working.The buzzer is (conventionally) wired in parallel to the step-retraction circuit, so I think it's lack of working is a symptom, rather than a cause, of the problem. It could be located anywhere, but I'd think the engine compartment is unlikely. Common locations are under either the driver's or passenger's seat, or, if the kitchen is near the habitation door, behind the kitchen drawers or cupboard. Generally a small black unit.
I'm pretty sure there are two relays, one for split charge, and one for fridge 12v, the latter also supplying the step retraction*. I don't think we've yet been told whether fridge 12v is actually working. Since the problem doesn't appear to be the dodgy fuse box, I'd want to check the 15A fuse position for 12V when the engine is running. It's relatively easy to access, and focuses the next step(s).
If 12v is present (and the fridge is OK), then the issue is in the wiring from the fuses to the step, or the step internal controls/relay. If 12v is not present, then you're looking at the circuit upstream of the fusebox, the wiring, the relay and the D+ signal from the alternator.
*It appears that the EMC relay is also fed from the same relay/fuse as the step. If it hasn't been messed with (as sometimes people have), a significant amount of the internal lighting should go off with the engine running. If this happens then it confirms there is power through to the 15A fuse in the fusebox.
For further clarification there are two relays involved with the step operation. As stated in my post #5 above the the fridge relay is operated from D+ (alternator field circuit). D+ is a low current supply which becomes live when the engine is started, and the alternator starts generating power. In order to avoid taking to much power from the D+ point, the supply to the step relay coil supply is connected to the output (fridge side) of the fridge relay. The step relay may be mounted close to the step (mine is under the kitchen sink), and hence separate from the fridge and split charge relays.
