Technical instrument panel no longer works
cjoosten
Roggel
Because I had to pull a cable, I removed the instrument panel (tachometer, km counter, etc.). Nothing exciting in itself, it's not the first time. Its 2 screws and the cover is off. Then 2 screws and a plug and the panel itself is removed. The difference with the previous removal is that I now started the car and moved it a bit (without the display being built in).
Everything was reinstalled and connected, but now the instrument panel no longer emits light. Everything remains dark.
I have checked fuses above the OBD2 plug but they all seem good. I tried to reach the dashboard/instrument panel with multiecuscan, but unfortunately that didn't work.
Does anyone have any ideas where else I can look or what else I can do? Or is it maybe that the ecu doesn't recognise the instrument panel because it was not there when i started the car.
Excuse for my English i come from the Netherlands
all fuses also in the engine compartment are ok. On the connector from the instrument panel (pin 1 + 2) is 12,4 volt.
