To my mind that's the best advice so far
I would always do this BEFORE trying to renew a snapped cambelt
If it feels like its binding when you rotate the cam you could then also remove the cam and its carrier from the head [head still on the block] to have a look at the top of the valves stems, springs and the collets
THEN with the cam off [so all valves should be shut] you can turn over the bottom end to check that it rotates freely
This is what I did on a Mitsubishi diesel engine in my 4x4 that is an interference engine when the belt tensioner bearing failed, bits of broken ball race dropped under the cambelt making it jump a few teeth on the crank pulley and the valves kissed the pistons [luckily when the engine was just idling] and the cambelt never even snapped!!! The engine just locked itself up dead!
Did all these checks, fitted a new cam belt, and the engine has run fine for the last year....
